hm_getoffset
Returns the offset value of the specified element.
hm_getoffset elem_id
HyperMesh Tcl Query Command
This command returns the offset value of the specified element.
elem_id
The ID of the element to query.
To get the offset for element 100:
hm_getoffset 100
   # Handle error
Version History
11.0
