hm_ce_imprintelemsget
Returns imprinted elements for a connector.
hm_ce_imprintelemsget id reserved
HyperMesh Tcl Query Command
id
The ID of the connector to query.
reserved
Reserved for future use, must be set to 0.
Examples
To get imprinted elements from the connector with ID 101:
set imprinted_elems [hm_ce_imprintelemsget 101 0]
   # Handle error
Version History
2021
