hm_getoption
Returns the value of certain HyperMesh options.
hm_getoption option?default?
HyperMesh Tcl Query Command
This command returns the value of certain HyperMesh options.
- option
- The option to query. See *setoption for a full list of options and possible values.
- default
- If set to 1, returns the default value instead of the current value, where supported.
hm_getoption cleanup_tolerancehm_getoption display_color-15Errors
# Handle error
}Version History
10.0
14.0.130 - Options brought in sync with *setoption.
