hm_ce_generatenamefrominclude
Returns a name using a base name and connector include ID.
hm_ce_generatenamefrominclude id base_name
HyperMesh Tcl Query Command
This returns a string like <base_name>_inc<ID> where ID is the include ID of the connector.
id
The ID of the connector to query.
base_name
The base name to append.
Examples
To generate a name for connector 2 and the base "hexa_comp":
hm_ce_generatenamefrominclude 2 "hexa_comp"
   # Handle error
Version History
2021
