hm_ce_mesh_imprint_option_get
Returns a mesh imprint option value.
hm_ce_mesh_imprint_option_get name
HyperMesh Tcl Query Command
name
Valid names are:
avoid_imprint
avoid_int_snapping
keep_snap
skip_imprint
skip_overlap_check
strict_imprint
To get the value of avoid_imprint:
hm_ce_mesh_imprint_option_get avoid_imprint
   # Handle error
Version History
11.0.101
