hm_comparegetarea
Calculates the area values for all source and target entities.
hm_comparegetarea match_type match_location ?transformation_index?
HyperMesh Tcl Query Command
Calculates the area values for all source and target entities. This must be preceded by a call to a relevant hm_compareentities* command.
match_type
The type of match to query for the area. Valid values are:
0 - Unmatched
1 - Topological
2 - Intersected
3 - Overlapped
4 - Matched
match_location
The location of the entities to query for the area. Valid values are:
1 - Source entities
2 - Target entities
The index of the transformation to query, starting with 0. The number of transformations can be found using hm_comparegettransformationcount.
To get the area of both the source and target unmatched entities for a same side comparison of elems 1-20 and 101-120:
*createmark elems 1 1-20
*createmark elems 2 101-120
hm_compareinit
hm_compareentitiessameside surfs 1 surfs 2 0.1 2 0
set unmatched_source [hm_comparegetarea 0 1]
set unmatched_target [hm_comparegetarea 0 2]
hm_compareend
   # Handle error
Version History
12.0
