hm_fe_setWvsTfile
Sets the width vs thickness file for seam welds.
hm_fe_setWvsTfile file
HyperMesh Tcl Query Command
file
The name and path of the width vs thickness file.
Examples
To set the file:
set wvstfile [file join [hm_info -appinfo HMBIN_DIR] WidthMappingTable.txt]
   # Handle error
Version History
2021
