hm_getmodelcheckenttype
Returns the entity type for the specified Model Check check display name.
hm_getmodelcheckenttype display_name
HyperMesh Tcl GUI Command
This command returns the entity type for the specified Model Check check display name.
display_name
The check display name.
To get the entity type for the check named "Unused Materials":
set enttype [hm_getmodelcheckenttype "Unused Materials"]
   # Handle error
Version History
11.0.101
