hm_getcleanupglobalflags
Returns the global flags currently being used for switching of some default modes for geometry autocleanup, element cleanup and element QI smoothing.
hm_getcleanupglobalflags flags
HyperMesh Tcl Query Command
This command takes as input a mask of flags used for controlling some of the default modes for geometry autocleanup, element cleanup and element QI smoothing. It returns a word representing the current status of the specified flags.
The commands which can be affected by resetting the global cleanup default flags using *setcleanupglobalflags are as follows:
*autotopocleanup
*hm_auto_elem_cleanup_new
*hm_batchmesh
*hm_failed_elements_cleanup
*optimsmooth
*qismoothfixfailed
*qismoothconstrained
- flags
 - Flags bit value that indicate the global settings to query. To query multiple flags at once, sum the bit values of the requested flags. The default value is 0 which returns the full current bit value of all flags.
Assign the current word of all flags to the variable prv_flgs. Setup the flags to ignore component boundaries and to not create auxiliary surfaces. Then element QI smoothing is performed. Finally, all flags are restored to their original state:
set prv_flags [hm_getcleanupglobalflags 0]
*setcleanupglobalflags 3 1
*createmark elements 1 "all"
*createmark nodes 1 ""
*optimsmooth 1 1 "C:/Altair/hw10.0/hm/batchmesh/8mm.criteria" 30.0 0.20 5 0
*setcleanupglobalflags $prv_flags 2
      To get the status of the fixed vertices creation:
set flag_4_status [hm_getcleanupglobalflags 4]
      To get the status of the component boundaries (1) and the fixed vertices creation (4):
set flag_5_status [hm_setcleanupglobalflags 5]
   # Handle error
}Version History
10.0
