hm_attributeindexentitytypename
Returns the entity type string of an indexed entity attribute on an entity.
hm_attributeindexentitytypename entity_type entity_name_or_id attribute_index ?search_type?
HyperMesh Tcl Query Command
entity_type
The type of entity to query.
entity_name_or_id
The name or ID of the entity.
attribute_index
The index of the attribute owned by the queried entity (starting at 1).
search_type
By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
-byname - Search only by name.
-byid - Search only by ID.
To get the attribute entity type string of the entity attribute with index 4 on property 1:
hm_attributeindexentitytypename props 1 4 -byid
   # Handle error
Version History
10-SA1-110
