hm_findadvancedselectiongroups
Finds advanced selection entities and separates them into selection method specific groups.
hm_findadvancedselectiongroups entity_type mark_id ?method? ?angle?
HyperMesh Tcl Query Command
entity_type
The type of entity to query. Must be set to surfs.
mark_id
The ID of the mark of entities to query. Valid values are 1 and 2.
method
The advanced selection method. Valid values are:
"by attached"
by face"
"by face across t junctions"
This value can be omitted, in which case "by attached" is used.
angle
The feature angle value used for faces detection. The value can be omitted, in which case the default feature angle value is used.
Examples
To find all groups of connected surfaces:
*createmark surfs 1 all
hm_findadvancedselectiongroups surfs 1 "by attached"
   # Handle error
Version History
2019
