hm_getsketchdata
Queries the information about the entities present in the sketch.
hm_getsketchdata <select_type>=<selection> entitytype=<value> sketchdata=<value>
HyperMesh Tcl Query Command
Queries the information about the entities present in the sketch data.
The entity or entities that are to be queried. There are several ways to provide the entities to be queried. Only one option can be used at a time:
id=<sketch_id>
The ID of the sketch entity.
name=<sketch_name>
The name of the sketch entity.
entitytype=<value>
The type of queried entity present in the sketch.
sketchdata=<value>
The queried sketch entity data name.
To query list of point IDs from sketch ID 1:
*hm_getsketchdata id=1 entitytype=point sketchdata=entitylist
   # Handle error
Version History
2021.2
