hm_getentityinfo
Returns definition information for an entity, either corresponding to the data name specified or all data names for that entity.
hm_getentityinfo entity_type definition ?option=<value>?
HyperMesh Tcl Query Command
This command returns definition information for an entity, either corresponding to the data name specified or all data names for that entity.
entity_type
The entity type to query.
definition
The definition to query. If dataname is not specified, values for all data names of the specified entity_type are returned. Return values for all definitions are in the same order so they are easily matched together. If data_name is specified, only the definition value for that data name is returned.
Valid definition types are:
arraydimension - Returns 0 for data names that are single values, 1 for arrays.
datatype - Returns the data type name (string, integer, double, etc...).
displayname - Returns the default display name.
editable - Returns the editable state EDITABLE or NONEDITABLE.
namedidentifier - Returns the data name string name.
visible - Returns the visibility state VISIBLE or INVISIBLE.
option=<value>
The option to be used to modify the command return value. Only one option can be used at a time:
config=<config>
  • The return values will only be those associated with the specific entity type config. This is not valid for entities without a config, nor for legacy entities that do have a config (such as elems, loads, groups, beamsects, laminates, tables, bags).
dataname=<data name>
  • The return value will only be for the specified data name.
Examples
To get all of the data names for elements:
hm_getentityinfo elems namedidentifier
To get all the array dimension of the component data name 'elements':
hm_getentityinfo comps arraydimension dataname=elements
To get all the data names associated with region config 1:
hm_getentityinfo regions namedidentifier config=1
   # Handle error
Version History
13.0
