hm_getcog
Returns the mass center-of-gravity coordinates for the selected entities.
hm_getcog entity_type mark_id
HyperMesh Tcl Query Command
Returns the mass center-of-gravity coordinates for the selected entities. The coordinates are always returned relative to the global axes.
entity_type
The type of entity to query. Currently supported for comps, elems, mats, props, parts, assems, plies and laminates.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
To get the COG for components 1-5:
*createmark comps 1 1-5
hm_getcog comps 1
   # Handle error
Version History
11.0.101
2021.2 - Added new supported entity types mats, props, parts, assems, plies, and laminates.
