hm_getmass
Returns the mass, volume and area of the selected elements or components.
hm_getmass entity_type mark_id ?mass_type?
HyperMesh Tcl Query Command
This command returns the mass, volume and area of the selected elements or components.
entity_type
The type of entities to consider. Valid values are elems, comps, mats, props, parts, assems, plies, and laminates.
mark_id
The ID of the mark. Valid values are 1 and 2.
mass_type
The type of mass to output.
0 - All mass values
2 - structural mass
3 - non-structural mass
4 - rigid mass
5 - lumped mass
6 - transferred mass
7 - engineering mass
8 - distributed mass
To get the mass for elements 1-100:
*createmark elems 1 1-100
set temp [hm_getmass elems 1]
set mass [lindex $temp 0]
set vol [lindex $temp 1]
set area [lindex $temp 2]
   # Handle error
Version History
10.0
2019 - Added new optional mass_type argument.
2021.2 - Added new supported entity types mats, props, parts, assems, plies, and laminates.
