hm_ce_getprojnodeid
Returns the node ID for the projection data layer of interest.
hm_ce_getprojnodeid index layer
HyperMesh Tcl Query Command
This command returns the node ID for the projection data layer of interest. The node corresponds to the part the weld is connecting at that location.
This function should only be called from within a connector-registered property script (which is executed during connector FE realization). The projection data this function relies upon is removed immediately after connector FE realization.
index
The index of interest in the array (corresponds to a weld).
layer
The independent (1) or the dependent (0) layer the weld connects.
To get the projection node ID for index 5 and independent layer (1):
set num_of_projs [hm_ce_getnumoffeprojinfo];
set layer 1;
foreach index $num_of_projs {
     if {$index == 5} {
         set node_id [hm_ce_getprojnodeid $index $layer];
         break;
   # Handle error
Version History
10.0
