hm_is_dirtiness_detection_enabled_for_entitytype
Informs if automatic dirtiness detection is enabled for the entity type.
hm_is_dirtiness_detection_enabled_for_entitytype entity_type
HyperMesh Tcl Query Command
An automatic mechanism marks includes/modules dirty (modified) when they or entities belonging to them are changed. They get “cleaned” when exported (for includes) or saved as representations (for modules).
This query informs whether the automatic detection mechanism is active or not for a specific entity type. By default, if not manually disabled, it’s always active. This is useful to be asked before manual manipulation of the automatic mechanism, to store and restore the previous state.
entity_type
Currently, only includes and modules are valid entity types.
Examples
Asks whether the automatic detection mechanism is active for include files:
hm_is_dirtiness_detection_enabled_for_entitytype includes
if { [ catch {hm_is_dirtiness_detection_enabled_for_entitytype mats} ] } {
   # Handle error
Version History
2021.2
