hm_getsurfacesfromsolid
Returns the list of surface IDs associated with a specified solid ID.
hm_getsurfacesfromsolid id ?type?
HyperMesh Tcl Query Command
- id
 - The ID of the solid to query.
 - ?type?
 - An optional string to specify which surfaces are returned. Valid values are bounding, partition, fin and all (default).
To get a list of surfaces associated with solid of ID 1:
hm_getsurfacesfromsolid 1
      This command returns information necessary for running other commands related to surface and solid creation.
None.
Version History
2017.1 - Added new optional argument type to filter the found and returned surfaces.
