hm_entityminsolverid
Returns the minimum solver ID in use for an entity type.
hm_entityminsolverid entity_type ?id_pool_name?
HyperMesh Tcl Query Command
entity_type
The type of entity to query.
id_pool_name (optional)
Indicates whether the minimum internal ID should be considered over all ID pools or a specific ID pool only.
Examples
To get the minimum solver ID for properties:
hm_entityminsolverid props
To get the minimum solver ID for properties in the two_idpool property ID pool:
hm_entityminsolverid props two_idpool
   # Handle error
Version History
13.0
