hm_ce_alldetailsget
Returns all custom details assigned to a connector.
hm_ce_alldetailsget id reserved
HyperMesh Tcl Query Command
id
The ID of the connector to query.
reserved
Reserved for future use. Must be set to 0.
To get all the details associated with connector ID 1:
hm_ce_alldetailsget 1 0
   # Handle error
Version History
9.0
