*CE_DetailSetUint
Sets an unsigned integer as connector detail for a connector specified by ID.
*CE_DetailSetUint ce_id detailName uint_val unknownFlag force_storage_flag
HyperMesh Tcl Modify Command
- ce_id
 - ID of the connector to which you wish to attach detail.
 - detailName
 - Name for a user-defined unsigned integer detail.
 - unit_val
 - The unsigned integer value for the detail.
 - unknownFlag
 - Reserved for future use. Must be set to 0.
 - force_storage_flag
 - The flag indicating whether or not to store a user-defined detail.
- 1 = yes
 - 0 = no
Examples
*CE_DetailSetUint(1, "test", 2.0, 0, 1)There are currently no standard unsigned integer details, only user-defined ones.
