*hf_ClearLLHandles
Delete all the handles from the model.
*hf_ClearLLHandles int_flag
HyperMesh Tcl Modify Command
This command deletes all the handles and the handles node pointer from the model.
- int_flag
 - Integer dummy value. Should always be set to 0.
*hf_ClearLLHandles 0Errors
   # Handle error
