*addtransformation
Adds transformations to positions.
*addtransformation mark_id1 mark_id2
HyperMesh Tcl Modify Command
Alternatively, *setvalue can be used.
mark_id1
The ID of the mark containing the position entities to which the transformations in mark_id2 must be added to.
mark_id2
The ID of the mark containing the transformation entities to be added.
Examples
To add all the transformations to all the positions:
*createmark positions 1 all
*createmark transformations 1 all
*addtransformation 1 1
   # Handle error
Version History
2019
