*morphmapedgestonodelistoffset
Maps selected morph volume edges to the specified node list.
*morphmapedgestonodelistoffset user_mark_id node_list_id use_symmetry use_constraints project vector_id number_of_mid_handles offset
HyperMesh Tcl Modify Command
This command will fit (evenly distribute) or project (along vector or normal) the handles on the marked morph volume edges to a line calculated from the specified points.
user_mark_id
The ID of the user mark containing the morph edges. Valid values are 0-3.
node_list_id
The ID of the list containing the input nodes. Valid values are 1 and 2.
use_symmetry
0 - Do not use symmetry links
1 - Use symmetry links
use_constraints
0 - Do not use constraints
1 - Use constraints
project
0 or 10 - Project along vector defined by vector_id
1 or 11 - Project normal to line
2 or 12 - Fit to line
If offset is non-zero, the offset will be measured from the closest point on the line for values of 0 and 1. The offset will be measured along the projection vector or normal for values of 10 and 11. Offsets will not be applied for a value of 2.
vector_id
The ID of vector created using *createvector for the projection direction. Must be set to 1.
-1 - Do not change the handles on the edges
0 - 5 - Update the number of mid-handles on the edges to this number
offset
The distance to offset nodes from the target. Not used if project is 2.
The offset will be measured from the closest point on the line for values of project of 0 and 1. The offset will be measured along the projection vector normal for values of project of 10 and 11.
Examples
To map edges on mark 0 offset by 1.2 from a node list along a vector leaving the handles unchanged:
*morphmanageedgemark 0 0 3
*morphmanageedgemark 2 0 1
*morphmanageedgemark 4 0 1
*createlist nodes 1
*createvector 1 1.0 0.0 0.0
*morphmapedgestonodelistoffset 0 1 1 1 0 1 -1 1.2
To map edges on mark 1 to a node list along the node list normal with 3 mid-handles per edge:
*morphmanageedgemark 0 1 3
*morphmanageedgemark 2 1 1
*morphmanageedgemark 4 1 1
*createlist nodes 1
*morphmapedgestonodelistoffset 1 1 1 1 1 1 3 0.0
   # Handle error
Version History
2020.1
