*displayelementsbyproperty
Controls the display of elements that have either a direct, indirect or mixed property assignment.
*displayelementsbyproperty mode type
HyperMesh Tcl Modify Command
- mode
 - The mode to control the element display. Valid values are:
- on - Turn on the elements.
 - off - Turn off the elements.
 - reverse - Reverse the display of the elements (if off, turn on and if on, turn off).
 - isolate - Isolate the display of the elements (turn off all others).
 - type
 - The property assignment type to use for selecting the elements to display. Valid
            values are:
- 0 - Direct property assignment.
 - 1 - Indirect property assignment.
 - 2 - Any property assignment.
*displayelementsbyproperty on 0Errors
   # Handle error
}Version History
11.0
