*elementsaddnodesfixed
Marks the specified nodes of the old elements as fixed nodes (nodes that must be retained in the mesh to be created) before using the commands for remeshing/meshing by elements.
*elementsaddnodesfixed elements_mark, nodes_mark
HyperMesh Tcl Modify Command
- elements_mark
 - The mark of elements that are considered for remeshing/meshing by elements. Valid values are 1 and 2.
 - nodes_mark
 - The mark of nodes specifying the nodes to be retained in the new mesh. Valid values are 1 and 2.
*createmark(elements,1) 154 155 158 159 160 161 164 165 339 341 343 345 347
*createmark(nodes,2) 210 277 370
*elementsaddnodesfixed(1,2)
*defaultremeshelems(1,3.0,2,2,0,1,1,1,0,0,0,0,0,30)Using *elementsaddnodesfixed() implies that it will be followed by a command that performs remeshing/meshing by elements. For example, *defaultremeshelems(), *defaultmeshelems(), *interactiveremeshelems(), or *interactivemeshelems(). *createmark() directive is required for this command.
Version History
9.0
