*window_entitymark
Fits the view to the entities on the mark.
*window_entitymark entity_type mark_id
HyperMesh Tcl Modify Command
entity_type
The type of entity to fit.
mark_id
The ID of the mark of entities to fit. Valid values are 1 and 2.
Examples
To fit the view to elements 1-10:
*createmark elems 1 1-10
*window_entitymark elems 1
   # Handle error
Version History
2019
