*lines_approximate
Simplifies curved free lines.
*lines_approximate mark_id type reserved1 reserved2
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the free lines. Valid values are 1 and 2.
 - type
 - 1 - Each curved line will be replaced with a parabola (2nd degree) that has the same end points as the line, and is closest to it.
 - reserved1
 - Reserved for future use. Must be set to 0.
 - reserved2
To simplify lines 1 and 2 using Bezier simplification:
*createmark lines 1 1 2
*lines_approximate 1 2 0 0
   # Handle error
}Version History
11.0
