*elementqualitydragtriaelem
Moves a tria element towards a specified point within the interactive cleanup tool.
*elementqualitydragtriaelem elem_id px py pz merge_tria end
HyperMesh Tcl Modify Command
This command, within the interactive cleanup tool, moves a tria element towards a specified point.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
elem_id
The tria element ID.
px py pz
Coordinates of a point that defines the drag direction.
merge_tria
0 - Do not merge trias when they are close together.
1 - Merge trias when they come close together.
end
0 - This is an intermediate movement and there are additional movements following this one.
1 - This is the last call of this command.
To drag tria element 3 towards (5.7, 3.78, 991.0) using quality criteria from a file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualitydragtriaelem 3 5.7 3.78 991.0 0 1
*elementqualityshutdown 1
   # Handle error
Version History
13.0
