*removeedgefillets
Defeatures surface edge fillets.
*removeedgefillets mark_id min_radius max_radius min_angle failed_elem_size
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the input surfaces. Valid values are 1 and 2.
min_radius
The minimum value of the fillet radius.
max_radius
The maximum value of the fillet radius.
min_angle
Minimum value of the fillet angle (in degrees).
failed_elem_size
Filters out edge fillets with an angle point within failed_elem_size from other face vertices. Additionally, it internally filters out some concave edge fillets on "shelves" so that they are not cut by the defeature operation.
To delete all edge fillets with a radius between 3 and 5, with an angle greater than 15 degrees:
*createmark surfs 1 all
*removeedgefillets 1 3 5 15 0
   # Handle error
