*surfacemarkaddnodesfixed
Add fixed points to a surface at locations specified by nodes.
*surfacemarkaddnodesfixed surf_mark_id node_mark_id tol reserved_1
HyperMesh Tcl Modify Command
- surf_mark_id
 - ID of the mark containing the input surfaces to add fixed points to. Valid values are 1 and 2.
 - node_mark_id
 - ID of the mark containing the nodes to use to define the fixed point locations. Valid values are 1 and 2.
 - tol
 - Tolerance value used to determine if a node is close enough to a surface.
 - reserved_1
 - Reserved parameter, must be set to 0.
To add fixed points to the surface with ID 12 at positions specified by nodes with IDs 1 and 2:
*createmark nodes 1 1 2
*createmark surfs 1 12
*surfacemarkaddnodesfixed 1 1 0.1 0
   # Handle error
