*metadatamarkdouble
Creates double metadata on the specified mark of entities.
*metadatamarkdouble entity_type mark_id name value
HyperMesh Tcl Modify Command
entity_type
The type of entities contained on the mark.
The undef entity type is used to store metadata on the model itself.
mark_id
The ID of the mark containing the entities to which the metadata will be added. Valid values are 1 and 2.
name
The name by which the metadata will be referenced.
value
The double value assigned to the metadata.
To add metadata named Real_Val with the value 17.54 to elements 1-100:
*createmark elems 1 1-100
*metadatamarkdouble elems 1 "Real_Val" 17.54
   # Handle error
