*detachallelements
Detaches elements from each other and from the attached structure, using the specified offset value.
*detachallelements mark_id offset
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark of elements to detach. Valid values are 1 and 2.
 - offset
 - The distance by which the elements should be offset from the attached structure.
*createmark elems 1 10
*appendmark elems 1 adjacent
*detachallelements 1 0Errors
   # Handle error
}Version History
14.0
