*contactsurfcreatewithshells
Creates a contact surface using 1D or 2D elements.
*contactsurfcreatewithshells name color mark_id reverse_normals
HyperMesh Tcl Modify Command
- name
 - The name of the contact surface to create.
 - color
 - The color of the contact surface. Valid values are 1 through 64.
 - mark_id
 - The ID of the mark that contains the 1D and 2D elements to use. Valid values are 1 and 2.
 - reverse_normals
 - 0 - Create contact surface along element normal.
Examples
*createmark elems 1 1-100
*contactsurfcreatewithshells "test" 5 1 0Errors
   # Handle error
