*fillplot
Generates a fill plot.
*fillplot title mesh_color fill_color full_size blocks
HyperMesh Tcl Modify Command
title
The fill plot title.
mesh_color
The color of the mesh. Valid values are 1 through 64.
  • -1 - Uses the elements color.
  • 0 - Uses the background color.
fill_color
The color of the center of the elements. Valid values are 1 through 64, or -1 to use the element colors.
full_size
Determines whether the fill plot fills the entire screen. Valid values are:
  • 0 - Use normal size.
  • 1 - Use full screen. Click a mouse button to return.
blocks
This option is ignored and should be set to 0.
To generate a normal size fill plot with the title "This is the title", a mesh color of black, and a fill color equal to that of each element:
*fillplot "This is the title" 0 -1 0 0
