*pushtofront
Sets a visualization mode to keep certain entities visible in front of others.
*pushtofront entity_type mode
HyperMesh Tcl Modify Command
entity_type
The type of entity to control. Valid values are tags.
mode
0 - Do not push to front (default)
1 - Push to front (keep in front of other entities at all times)
To keep tags in front:
*pushtofront tags 1
   # Handle error
Version History
12.0.110
