*CE_ReviewConnectorsReverse
shortDescription
*CE_ReviewConnectorsReverse entity_type string_array number_of_strings output_mark_id
HyperMesh Tcl Modify Command
longDescription
- entity_type
 - The entity type on which the reverse review operation will be performed. Valid values are connectors and attachments.
 - string_array
 - The string array ID that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
 - number_of_strings
 - Integer indicating the size (number of strings) in the string array created using *createstringarray.
 - output_mark_id
 - The ID of the mark onto which the reviewed entities are placed. Valid values are 1 and 2.
Examples
*createstringarray 4 "realization_connector=1" "first_connector_entity=1" "linked_entity=0" "second_connector_entity=0"
*CE_ReviewConnectorsReverse connectors 1 4 2Errors
   # Handle error
}Version History
2021
