*midmesh_inspect_end
Clears memory and ends the midmesh inspection module.
HyperMesh Tcl Modify Command
Clears memory and ends the midmesh inspection module. This must be preceded by any calls to *midmesh_inspect_init and other *midmesh_inspect_* APIs.
None.
Examples
To detect and correct nodes off mid, delete empty sets, and shut down the inspect module:
*createmark components 1 "shell"
*createmark components 2 "MidmeshEdges" "Mid"
*midmesh_inspect_init SourceEntityType=components SourceMark=1 TargetEntityType=components TargetMark=2 MinNodeOffMidDeviation=0.2
*midmesh_inspect_fix_problems nodes 2 ProblemType=NodeOffMid SmoothClusters=1 SmoothMethod=Auto
*midmesh_inspect_delete_sets 2
   # Handle error
Version History
2021
