*markprojecttosurface
Project entities to a surface.
*markprojecttosurface entities mark vector surface
HyperMesh Tcl Modify Command
entities
The type of entity contained on the mark.
mark
The ID of the mark.
vector
The direction to project the entities.
surface
The ID of the surface to project to.
To project elements 109 and 131 to surface 1 along the Z-axis:
*createmark(elements,1) 109 131
*createvector(1,0.0000,0.0000,1.0000)
*markprojecttosurface(elements,1,1,1)
*createmark() and *createvector() are required for this command.
