*setcomponentdisplayattributes
Sets a component to the specified style and color.
*setcomponentdisplayattributes name style colortype
HyperMesh Tcl Modify Command
name
The name of the component.
style
Set to:
  • 0 - Wire frame
  • 1 - Hidden line
  • 2 - Hidden line with mesh
  • 3 - Hidden line with features
  • 4 - Hidden line transparent
colortype
Determines how the component is colored. The options are:
  • 0 - None
  • 1 - Component color
  • 2 - Assigned plots
  • 3 - Contours
None.
