*copymark
Copies entities from one collector to another.
*copymark entity_type mark_id name
HyperMesh Tcl Modify Command
- entity_type
 - Entity type to copy. Any collected entity type (aside from main/secondary elements) is valid.
 - mark_id
 - The ID of the mark containing the entities to copy. Valid values are 1 and 2.
 - name
 - The name of the collector to copy the entities to. The collector type is determined by the entity_type.
Examples
*createmark elems 1 "by collector name" comp1
*copymark elems 1 comp2Errors
   # Handle error
