*lineplot
Generates a line plot.
*lineplot title full_size
HyperMesh Tcl Modify Command
title
The title of the line plot.
full_size
Determines whether the line plot fills the entire screen. Valid values are:
0 - Use normal size.
1 - Use full screen. Press a mouse button to return.
To generate a normal size line plot with the title "This is the title":
*lineplot "This is the title" 0
None.
