*hf_CheckDieModuleElementsRES
Creates and visualizes the contour of draw depth, trim angle and undercut.
*hf_CheckDieModuleElementsRES entity_type_part mark_id_part entity_type_binder mark_id_binder vector_id flag
HyperMesh Tcl Modify Command
This command creates and visualizes the contour of draw depth, trim angle and undercut of the elements part with respect to the binder surface. The draw depth, the trim angle and the undercut value are evaluated with respect to the stamping direction.
- entity_type_part
 - The entity type of the part. Must be set to elems.
 - mark_id_part
 - The mark ID containing the part entities. Valid values are 1 and 2.
 - entity_type_binder
 - The entity type of the binder. Must be set to surfs.
 - mark_id_binder
 - The mark ID containing the binder entities. Valid values are 1 and 2.
 - vector_id
 - The temporary vector ID created using the *createvector command that defines the stamping direction.
 - flag
 - A flag that indicates what to visualize. Valid values are:
- -2 - Trim angle on trim line.
 - -1 - Draw depth between part and z=0 plane.
 - 1 - Draw depth between part and binder.
 - 2 - Trim angle on the part.
 - 3 - Undercut on the part.
*createmark elems 1 displayed
*createmark surfs 1 displayed
*createvector 1 0.0 0.0 1.0
*hf_CheckDieModuleElementsRES elems 1 surfs 1 1 1Errors
   # Handle error
}Version History
11.0
