*hwct_addrepsfromlibrary
Adds representations from a connected library.
*hwct_addrepsfromlibrary entity_type mark_id rep_alias_list params
HyperMesh Tcl Modify Command
entity_type
The type of connected library. Currently only supported for subsystems.
mark_id
The ID of the mark of entities. Valid values are 1 and 2.
rep_alias_list
The list of representation alias names to load.
params
A quoted, comma separated string, containing additional optional name=value parameters. Valid parameters are:
load=<value>
0 - Do not load the rep alias for the subsystem
1 - Load the rep alias for the subsystem
overwrite=<value>
0 - Do not overwrite the session information
1 - Overwrite the session information
repfolder=<value>
The folder in which the representation exists.
Examples
Load a crash representation for subsystem 2 from C:/temp/subsystems:
*createmark subsystems 1 2
*hwct_addrepsfromlibrary subsystems 1 crash "overwrite=1, repfolder=c:/temp/subsystems"
   # Handle error
Version History
2020
