*createvector
Defines a vector for use in a subsequent command.
*createvector vector_id x_component y_component z_component
HyperMesh Tcl Modify Command
The vector length should never be 0.
Use the *createetity command to create a vector entity.
- vector_id
 - The ID of the vector being defined. Valid values are 1 and 2.
 - x_component
 - The x-component of the normal of the vector.
 - y_component
 - The y-component of the normal of the vector.
 - z_component
 - The z-component of the normal of the vector.
Examples
*createvector 1 0.0 1.0 0.0
