*setcurrentmodel
Sets the specified model as curent.
*setcurrentmodel name
HyperMesh Tcl Modify Command
name
The name of the model to set current.
Examples
To set model named model-2 as current:
*setcurrentmodel model-2
   # Handle error
Version History
2019
