*morphsetsmoothignoredelems
Assigns elements to be ignored when performing element test criteria for shape combination checking via *morphshapesmooth.
*morphsetsmoothignoredelems entity_type mark_id
HyperMesh Tcl Modify Command
Assigns elements to be ignored when performing element test criteria for shape combination checking via *morphshapesmooth. Note that the excluded elements are retained in memory until this command is used to clear or change them, or until a new model is loaded.
- entity_type
 - Must be set to elems.
 - mark_id
 - The ID of the mark containing the elements to ignore. Valid values are 1 and 2.
To set all elements in the component boundary to be ignored:
*createmark elems 1 "by comp" boundary
*morphsetsmoothignoredelements elems 1
if { [ catch {*morphsetsmoothignoredelems...} ] } {
   # Handle error
}Version History
14.0
