*CE_AddLinkEntities
Update connectors with entities.
*CE_AddLinkEntities connector_mark_id entity_type entity_mark_id
HyperMesh Tcl Modify Command
This command updates connectors with entities.
- connector_mark_id
 - The ID of the mark containing the connectors to update. Valid values are 1 and 2.
 - entity_type
 - Type of entity to be added to the connectors as links.
 - entity_mark_id
 - The ID of the mark containing the entities to use as links. Valid values are 1 and 2.
Examples
*createmark connectors 1 1-3
*createmark comps 1 1 2
*CE_AddLinkEntities 1 comps 1Errors
   # Handle error
