*CE_ConnectorPartition
Partitions seam connectors.
*CE_ConnectorPartition connector_mark_id non_normal use_tol tol passed_comp_type passed_comp number_passed_type passed_start_id failed_comp_type failed_comp number_failed_type failed_start_id backup backup_comp_type backup_comp
HyperMesh Tcl Modify Command
This command can be used to partition seam connectors. Each test point is tested for at least two available projections. This happens with respect to the tolerance specified on the connector or to the tolerance given in the command. The connectors become partitioned into passed and failed seam connector pieces. These connectors can be organized in different components and follow certain numbering rules. The original connectors can also be backed up.
connector_mark_id
The mark ID containing the connectors to update. Valid values are 1 and 2.
non_normal
0 - Use normal projection (recommended, <5° is considered normal).
1 - Use non-normal projection.
use_tol
Flag indicating the tolerance to use.
  • 0 - Use original tolerance.
  • 1 - Use tolerance by tol.
tol
The tolerance to use if use_tol is 1.
passed_comp_type
The method to store the passed connectors.
  • 0 - Passed connectors will be organized into the newly created component "CE partition passed".
  • 1 - Passed connectors will be organized into the current component.
  • 2 - Passed connectors will be organized into the connectors' original component.
  • 3 - Passed connectors will be organized into the specified component passed_comp.
passed_comp
The name of the component to use if passed_comp_type is 3.
number_passed_type
Method to renumber passed connectors.
  • 0 - Passed connectors will be renumbered/created beginning with the connector ID defined by passed_start_id. Any IDs already is use are skipped.
  • 1 - Passed connectors will be renumbered/created beginning with lowest available (unused) connector ID.
passed_start_id
Connector ID for renumbering the passed connectors when number_passed_type is set to 0.
failed_comp_type
The method to store the failed connectors.
  • 0 - Failed connectors will be organized into the newly created component "CE partition failed".
  • 1 - Failed connectors will be organized into the current component.
  • 2 - Failed connectors will be organized into the connectors' original component.
  • 3 - Failed connectors will be organized into the specified component failed_comp.
failed_comp
The name of the component to use if failed_comp_type is 3.
number_failed_type
Method to renumber failed connectors.
  • 0 - Failed connectors will be renumbered/created beginning with the connector ID defined by failed_start_id. Any IDs already is use are skipped.
  • 1 - Failed connectors will be renumbered/created beginning with lowest available (unused) connector ID.
failed_start_id
Connector ID for renumbering the failed connectors when number_failed_type is set to 0.
backup
Flag indicating whether to backup the original connectors before partitioning.
  • 0 - Do not backup.
  • 1 - Backup.
backup_comp_type
The method to store the backup connectors if backup is 1.
  • 0 - Backup connectors will be organized into the newly created component "^CE partition backup".
  • 1 - Backup connectors will be organized into the specified component backup_comp.
backup_comp
The name of the component to use if backup_comp_type is 1.
Examples
Partition the connectors 1-100. This is done using a normal projection with a tolerance of 20. The passed connectors will be moved into the original connector component and their IDs will continue. The failed connectors will be moved into the new "CE partition failed" component, and will begin with ID 5000. No backup of the original connectors will be made.
*createmark connectors 1 1-100
*CE_ConnectorPartition 1 0 1 20.0 2 "" 1 1 0 "CE partition failed" 0 5000 0 0 ""
   # Handle error
Version History
11.0.101
