*xyplotmodify
Modifies an xy plot.
*xyplotmodify plot name item name string value plot
HyperMesh Tcl Modify Command
- plot name
 - The name of the plot to be modified
 - item name
 - The name of the data item associated with the xy plot which should be modified.
 - string
 - The string value of the data item.
 - value
 - The value of the data item.
 - plot
 - A logical which determines if the xy plot should be redrawn after modification.
None.
